Connection Mirroring
Hi all,
I have 2 Big-ip devices on my test environment and i have checked connection mirroring works or not. I have build http service and check the mirroring but i realized that connections are not duplicated to the standby device as i expected.
I believe that i can see connections on the standby unit in real time ? am i wrong ?
Devices are connected to each other with dedicated cable from 1.2 interface (vlan_ha) and primary mirroring must be working over this link.
Also, devices has 11.4.1 Hotfix 4 software.
Regards.
- Vitaliy_Savrans
Nacreous
about connection and persistance mirroring link.
Check on standby unit:
(tmos) show sys connection (tmos) show ltm persistence persist-records - Seckin_149390
Hi Vitaliy,
I was already checked on the standby unit with command but i can not see the existing connection on the stanby unit.
For vlan_ha, port lockdown setting is Allow_Default but i know that TCP 1028 port is an exception and must be worked regardless of port lockdown settings.
Regards.
