hc_andy_35682
Feb 10, 2010Connection Mirroring and IRule Problem
Hi All,
New to the wonderful world of F5 and getting this error when trying to run connection mirroring and iRule.
This is the iRule we're using to permit only trusted IP Addresses access to the real and virtual servers. Pretty basic iRule. We apply this to all forwarding VIPS and Virtual Servers.
when CLIENT_ACCEPTED {
if { [matchclass [IP::client_addr] equals $::trustedAddresses] }{
Uncomment the line below to turn on logging.
log local0. "Valid client IP: [IP::client_addr] - forwarding traffic"
log local0. "Invalid client IP: [IP::client_addr] - discarding"
discard
Here's what happens...
* If iRule is applied to the VIP, we can't enable connection mirroring.
01070734:3: Configuration error: Mirroring is not supported on virtual servers that have cmp disabled and are configured with a fastL4 profile (VMTEST_HTTP)
* If connection mirroring is already enabled on the VIP, we can't add the iRule.
Appears to be one of the other...why is this so???
Our VIPS are using a fastL4 profile. Not 100% sure about cmp, read what I can find about it but it appears to be some feature that allows the CPU to load share the work load better.
Any help would be appreciated.
Thanks.
Andy
- spark_86682Historic F5 AccountI'm not sure why mirroring and a cmp disabled virtual server are incompatible. However, the easy and obvious fix is to change:
toif { [matchclass [IP::client_addr] equals trustedAddresses] }{
Usually, the "$::" prefix refers to a global variable, which is not compatible with CMP. On recent versions (9.4.2 (I think) and later) removing the "$::" will allow the matchclass command to work, while not making the system think you are using a global variable. This will also allow your virtual server to run on all processors, not just one (this is what CMP is), which can have a significant performance impact. - hoolio
Hi Andy,
Also, if the connections through the VIP are short lived, connection mirroring is generally not worth the additional resources it requires. Specifically, for HTTP, it doesn't make sense to use connection mirroring as the protocol can handled a brief drop at the TCP layer. So if there is a failover, HTTP clients should recover automatically or with a refresh of the page.
Connection mirroring makes more sense for long lived connections that don't handle TCP resets, like telnet. SOL7222 has details on this:
SOL7222: Overview of connection and persistence mirroring
https://support.f5.com/kb/en-us/solutions/public/7000/200/sol7222.htmlbestpractice
Aaron - hc_andy_35682
Hi Aaron,
I've read that article you mention. Thanks for the link.
What about such things as proxy servers that handle http requests. We load balance 10+ proxy servers on the F5. All currently have connection mirroring enabled. Not 100% sure if they should have connection mirroring enabled or not.
Cheers.
Andy
