connection limit and redirection rule using i-file
Hi
I need help to create i-Rule which is handling connection limit on pool member and redirection using i-file
i-file html code is below
현재 동시 접속자가 많아 접속이 원활하지 않습니다.
잠시 후 다시 접속하여 주시기 바랍니다.
could you advice sample rule or guide?
thank you.
- swjo_264656
HTML code is below I modify little to show you code.
HTML>
BODY>
P>
P STYLE='text-align:center;'>현재 동시 접속자가 많아 접속이 원활하지 않습니다.
P STYLE='text-align:center;'>잠시 후 다시 접속하여 주시기 바랍니다.
/BODY>
/HTML>
- Leonardo_Souza
Cirrocumulus
This code share page looks to have what you are looking for:
https://devcentral.f5.com/codeshare?sid=730
To add the use of an iFile, see this wiki page:
https://devcentral.f5.com/wiki/irules.ifile.ashx
