Connection error: ssl_passthru:3778: not SSL (40)
I'm receiving the following errors on my LTM:
tmm3[10956]: 01260009:4: Connection error: ssl_passthru:3778: not SSL (40)
tmm2[10956]: 01260009:4: Connection error: ssl_passthru:3778: not SSL (40)
tmm[10956]: 01260009:4: Connection error: ssl_passthru:3778: not SSL (40)
tmm1[10956]: 01260009:4: Connection error: ssl_passthru:3778: not SSL (40)
I really appreciate some help to solve this issue. I have handling this case with F5 support, but it has been so difficult to find some root cause for that error. I receive some information that it would be caused by expired certificates, but all of them have already been excluded.
Thank you.
- Chris_Grant
Employee
This error is thrown when non ssl traffic is sent to a Virtual Server that has a clientssl profile on it. In all likelihood it can safely be ignored.
- VishnuGatla
Cumulonimbus
How did you find out that virtual server when you get these errors ?
- Chris_Grant
Employee
Shri, unfortunately the error doesn't identify the virtual server in question. I suppose you could put a redirect irule on your port 80 virtual servers (creating them if needed) in which case this error would never happen because a plain text inquiry to your virtual server would be redirected to port 443.
