Connection closed
Upon launching an F5 BIG-IP VE AMI on EC2 (I'm using the 25Mbps trial edition), I notice that I can establish SSH connection to the instance (as well as HTTPS connection), but can't log in at all.
Trying key-based login with the key pair provided by Amazon, I'm getting a "Connection closed by " error message.
Not necessarily looking for an instant answer as to what's wrong (although that would be welcome); but what bothers me most is that I have no idea how to even go about troubleshooting this.
Accessing via HTTPS, I can see the login prompt. Obviously I can't login though because I don't know what the admin password is (I read that I should SSH into the instance in order to reset the admin password).
Any ideas?
- Daniel_Epperson
Employee
Hi, I'm with F5 Support and we're currently looking into this issue.
- Mike_Dayton_108
Did you try username root password default over SSH?
- Riley_Schuit_82Historic F5 AccountThat will not work, it will require to use host based authentication in AWS.
- Isaac_S__177992
Yes. root/default gets me "Access denied". - Riley_Schuit_82Historic F5 AccountJust for informations sake; he is talking about how the root account's (that can not be accessed via the web interface) default password is 'default'. In AWS, you need to login via ssh as root that ties into your ssh key, then you can alter the admin password via the passwd command.
I have had issues in the past were it was resetting my attempted connection. After waiting a bit, just magically worked. I feel it was in relation to the EIP association with the private IP of the VPC. I blame AWS.
- ChrisMutzel_151
Altocumulus
I had this problem as well. In my case, I was working on the 11.6 version of bigIp, but mistakenly followed the instructions for bigIp 11.4 In the documentation the credentials were different "ec2-user@" versus "root@..." to log into the device on the mgmt port.
I am not sure if this is your problem, but I continually got the same "Connection closed", even when I double checked my private key matched the one stored in EC2.
