Configuring weblogic for user with Kerberos when using F5 APM module to handle Keberos authentication
When using the APM module of F5 to handle the Kerberos authentication what provider should be used within weblogic? If F5 will not be forwarding the request unless the user is Authorized then I would assume that maybe the only provider that needs to be registered in weblogic is the LDAP authentication provider to handle the authorization of the authenticated user. This is the process that would have taken place if we were using weblogic to handle the kerberos authentication.
Any idea if this is the correct assumption? Any suggestions would be helpful.
- kilokilo_193671
I would also like to know the answer to this question.... anyone??!!
