dootyfree_24038's avatar
dootyfree_24038
Apr 05, 2012
configuring ftp help
Hello,
I have configured what seems to be a ftp virtual server. Can connect and login, but when I try to "dir", unable to build data connection : connection refused. Seems not dynamically building data port connection. ASM is in the dmz. What's weird is that it works internally but does not work from outside(internet).
  • hoolio's avatar
    hoolio
    Do you have an FTP profile enabled on the virtual server? Are you using active or passive FTP?
    Manual Chapter: Load Balancing Passive Mode FTP Traffic with Data Channel Optimization
    https://support.f5.com/kb/en-us/products/big-ip_ltm/manuals/product/ltm-implementations-11-1-0/21.html
    Aaron
  • What's weird is that it works internally but does not work from outside(internet).what does internal mean? is it in internal (server) vlan?
    this is mine. ftp client ip is 172.28.19.251. it is in external vlan.
    [root@ve1023:Active] config  b virtual bar list
    virtual bar {
       snat automap
       pool foo
       destination 172.28.19.79:21
       ip protocol 6
       profiles {
          ftp {}
          tcp {}
    [root@ve1023:Active] config  b pool foo list
    pool foo {
       members 200.200.200.101:21 {}
    1 active mode ftp
    [root@centos251 tmp] ncftp 172.28.19.79
    NcFTP 3.2.0 (Aug 05, 2006) by Mike Gleason (http://www.NcFTP.com/contact/).
    Connecting to 172.28.19.79...
    (vsFTPd 2.0.5)
    Logging in...
    Login successful.
    Logged in to 172.28.19.79.
    ncftp / > set passive off
    ncftp / > cd pub
    Directory successfully changed.
    ncftp /pub > ls -l
    -rw-r--r--    1 0        0   1012865024   Apr  6  2012   BIGIP-11.1.0.1943.0.iso
    ncftp /pub > get BIGIP-11.1.0.1943.0.iso
    BIGIP-11.1.0.1943.0.iso:                               965.94 MB   22.09 MB/s
    [root@ve1023:Active] config  b conn show all
    VIRTUAL 172.28.19.79:21 <-> NODE 200.200.200.101:21   TYPE any   1/0
        CLIENTSIDE 172.28.19.251:33027 <-> 172.28.19.79:21
            (pkts,bits) in = (30, 1870)   out = (21, 2001)
        SERVERSIDE 200.200.200.10:33027 <-> 200.200.200.101:21
            (pkts,bits) in = (27, 2309)   out = (26, 1668)
        PROTOCOL 6   UNIT 1   IDLE 0 (300)   LASTHOP external 00:50:56:b3:03:8f
    VIRTUAL 172.28.19.79:21 <-> NODE 172.28.19.251:43590   TYPE any   1/0
        CLIENTSIDE 200.200.200.101:20 <-> 200.200.200.10:43590
            (pkts,bits) in = (113361, 169.4M)   out = (10740, 575012)
        SERVERSIDE 172.28.19.79:20 <-> 172.28.19.251:43590
            (pkts,bits) in = (10740, 575012)   out = (113361, 169.4M)
        PROTOCOL 6   UNIT 1   IDLE 0 (300)   LASTHOP internal 00:50:56:b3:01:0b
    2 passive mode ftp
    (vsFTPd 2.0.5)
    Logging in...
    Login successful.
    ncftp / > set passive on
    ncftp / > cd pub
    BIGIP-11.1.0.1943.0.iso:                               965.94 MB   18.07 MB/s
        CLIENTSIDE 172.28.19.251:33028 <-> 172.28.19.79:21
            (pkts,bits) in = (24, 1487)   out = (17, 1632)
        SERVERSIDE 200.200.200.10:33028 <-> 200.200.200.101:21
            (pkts,bits) in = (23, 1943)   out = (22, 1387)
    VIRTUAL 172.28.19.79:6925 <-> NODE 200.200.200.101:6925   TYPE any   1/0
        CLIENTSIDE 172.28.19.251:42992 <-> 172.28.19.79:6925
            (pkts,bits) in = (46521, 2.499M)   out = (489847, 731.8M)
        SERVERSIDE 200.200.200.10:42992 <-> 200.200.200.101:6925
            (pkts,bits) in = (489847, 731.8M)   out = (46521, 2.499M)
