bcrogerz's avatar
bcrogerz
Icon for Cirrus rankCirrus
Jun 30, 2010
Comments for Virtual Ip, Pool,Monitors
Hi All,
Just a small question
in LTM v9.0 and above , is there a command to add commnets to a Virtual IP
i know that the Virtual IP name is there , but want to know if we can add '' and type something like a comment that extends more than 32 characters .
  • hoolio's avatar
    hoolio
    Hi Roger,
    There isn't the ability in any LTM version to add comments to load balancing objects. If you think this would be useful, you could open a case with F5 Support and ask them to add such a feature. For all objects, you can add a name but there are length and character restrictions which cannot be bypassed.
    Aaron
  • Thanks Aaron
    i will get in touch with f5 , see if they can put this a ER
    Cheers,
    Roger
