Cristian_Teica_'s avatar
Cristian_Teica_
Mar 14, 2019
Cluster 2 LTMs and keep both configurations sets
Hi DevCentral Comm, I have a question regards to LTM's. We currently have 2 LTM’s (BIG-IP v13.1.1). Every LTM serving 1 environment with different sets of VS, pools certificates etc. We want to cluster them but keeping (merge) the configurations from both LTM’s (VS’s, irules, pools, SSL certificates). If I just cluster them they will keep both configurations? Thanks in advance, Criss.
  • Are both BIGIP configured in different networks?
    If yes, before merging configuration (which will be done manually from command line), you have to think about design...
    The easiest solution to manage this is to work with partitions / route domains : - one partition per environment - vlans are assigned per partition - one route domain per partition - one traffic group per partition (with priority to be active on previous env appliance if both are up)
    To configure vlans, configure first with fake vlan ID.
    Then in tmsh, you have to copy old configuration
    list ltm pool one-line
    list ltm virtual one-line
    list ltm profile one-line
    list ltm monitor one-line
    Copy all configuration returned in a notepad, Remove objects you don’t want to import in the new partition, then import it in new partition:
    cd /env1/
    load sys config merge from-terminal
    PASTE HERE THE CONFIGURATION
    END WITH CTRL-D
    To make sure you don’t miss some configuration, you can first import monitors, profiles.. then pools and finally virtual servers
