Mike_Young_6152's avatar
Mike_Young_6152
Nov 14, 2012
Closing Active Connections sooner for maintenance
Background on the problem:
I have a pool setup of 6 windows machines executing .NET web services in IIS 7.x. During a deployment process we use iControl to disable 3 servers at a time to update the web service code/configuration. The problem is it takes a very long time for active connections to those pool members to die off. I want to figure out a way to quickly and cleanly kill the connections. The pool is set to round robin.
I have done some searching on the forums here and have found questions similiar to mine but most involve taking all pool members out for maintenance. The solution usually involves an iRule to check active_pool_members <1 then redirect to a maintenance page.
A possible solution I have come up with but not tested is to add this iRule:
when HTTP_REQUEST{
switch [LB::status]{
"session_disabled" -
"down"{
HTTP::close
default{}
I believe it checks the status of the pool member selected for this request and if it is down or disabled it then calls the HTTP::close which is supposed to close the connection after the response is sent. https://devcentral.f5.com/wiki/irules.HTTP__close.ashx
This feels a bit convuluded and not the best approach. Has anyone run into this problem before or can validate I am on the right track?
-Mike
