Client traffic control
Hi, how can I use client traffic shaping on my network clients to ensure that voice traffic gets priority over everything else sent to and from them and my APM? Is this a common use case for traffic shaping? If so can someone run me through setting this up. Also if I want to make sure that one or a small number of clients don't use up all my bandwidth, can I do anything to limit the amount of traffic that goes to each one, or guarantee a minimum amount to each one perhaps?
Many thanks
- gbbaus_104974Historic F5 Account
Hi
What version are you running. Client rate shaping has changed over the last few versions.
Besides controlling bandwidth used by clients, Setting QoS bits in a packet is also possible, but only usefull if all the hops between the F5 and the client VoIP phone honor the QoS bits.
- TedSmith_143757
Thanks for the response. We just ran a proof of concept on 11.4.1 but have raised orders for some new units, so should be running 11.5. Like I say, we want to make sure that we can't have a few users swamp our internet pipe and also maintain voice quality, and yes we can honour the QoS bits end to end once they hit our internal network. Anything you can do to point me in the right direction to achieve that would be much appreciated.
Ok ... Have a look at Rate Shaping
http://support.f5.com/kb/en-us/products/big-ip_ltm/manuals/product/tmos-concepts-11-4-0/15.html
but also note:
About the direction setting
Using the Direction setting, you can apply a rate class to client or server traffic. Thus, you can apply a rate class to traffic going to a client, to a server, or to both client and server. Possible values are Any, Client, and Server. The default value is Any.
Specifying direction is useful in cases where the nature of the traffic is directionally-biased. For example, if you offer an FTP service to external clients, you might be more interested in limiting throughput for those clients uploading files to your site than you are for clients downloading files from your site. In this case, you would select Server as the direction for your FTP rate class, because the Server value only applies your throughput restriction to traffic going from the client to the server.
With the above in mind, you may also look at
https://devcentral.f5.com/Community/GroupDetails/tabid/1082223/asg/50/aft/3691/showtab/groupforums/Default.aspx
HTH
