Client Cert Inspection for Edge client
I'm setting up the edge client in the ipad and iphone to use client certificate check as authentication method. If the user has a valid certificate it connects to the VPN. I have a VS with a client SSL profile that has a client authentication enabled. When the user taps the connect button in their ipad's edge client they receive an error message: "Authentication failed. Please check your credentials or configuration."
In the APM logs I see the following:
"Rule to evaluate = "expr {[mcget {session.ssl.cert.valid}] == "0"}" variable "session.ssl.cert.valid" was not found in the local cache for session "xxxxxx"
I checked the sessions variable for that session and no SSL variables were set at all. Not sure why the SSL session variables are not being populated.
- Kevin_Stewart
Employee
Can you elaborate on your configuration?
Do you have the Edge client configured to "Use Certificate"?
Do you have a Trusted Certificate Authorities bundle that includes the issuer of the client's certificate?
- Dennis_Andrade_
We have the edge client configured to use certificate. yes. as far as the certificate, the users certificates in the ipads are issued by a sub CA. We have the root CA and the sub CA imported to the F5. I'm using the Root CA in the "Trusted Certificate Authority" I also tried to use the sub CA in the trusted certificate authority but I would receive another error message.
- Kevin_Stewart
Employee
You should have BOTH CA certificates in the Trusted Certificate Authorities bundle. To create a bundle, copy the base64 (PEM-encoded) content of the CAs' public certificates to a single text file, save that, then import it to the LTM as you would a certificate.
- Dennis_Andrade_
You got it! That worked! Thank you!!!
