Clarification of OneConnect profile's "idle-timeout-override"
Regarding "idle-timeout-override", states
"The Idle Timeout Override setting specifies the number of seconds that a connection is idle before the connection flow is eligible for deletion. You can use this setting to override the protocol profile time-out and increase the time-out value for connections once they are pooled for re-use."
My question: does the this override the (protocol profile) idle-timeout of both the original connection and reused connections, or, only the latter?
Hi Epaalx,
a new connection will be created and will use the protocol-specific idle timeout settings. If OneConnected is active and the connection is marked for reuse (aka. ONECONNECT::reuse enable), the connection will be put into your OneConnect pool. The Idle Timeout Override setting may then apply new timeout values to this connection...
If another connection will be created the LTM may create a new connection (if OneConnect session pool is currently busy) or it will reuse a previous OneConnect connection with the now changed Idle Timeout Override settings.
Cheers, Kai
- 3junior_134880
Can I use "Idle Timeout Override" to kill an existing connection? max-age will only not allow new connection to server. I am looking to kill existing connection after x amount of time without touching tcp profile
- Vijay_E
Cirrus
I think the TCP profile's idle timeout takes precedence. I am not 100% sure but you can sure try it out.
- 3junior_134880
anyone?
