Citrix Storefront 3.0 - F5 Load balancing
I was wondering if there's official documentation on load balancing (2) Citrix StoreFront 3.0 servers on the F5 BIG-IP? We currently have our F5 configured to point to one Citrix StoreFront 3.0 server externally and it's working well but we wanted to if there was a supported method to load balance (2) StoreFront 3.0 servers for internal and external access.
The only document I was able to find is the "citrix-vdi-iapp-dg.pdf" but I wanted to see if there was anything more than this document out there for this type of configuration. We are currently on version 11.6.0. Thanks.
- Richard__147088
I just created a virtual HTTPS server which loadbalances two Storefront 3.0 servers. Nothing fancy, just publishing the Storefront HTTPS website (apps etc.). Works fine. We use 11.5.1 HF8. Is that what you are lookign for, or is the more to it?
Regards,
Richard
- Damien_Solodow_
Are you able to launch the published apps from outside your firewall? Using APM as well or just LTM?
