jrmorris_151361's avatar
jrmorris_151361
Jan 27, 2016
Cisco Unity Connection web inbox giving HTTP error 500
I am trying to load balance the web inbox of Cisco Unity connection. I get the login page and can login, then once I try hitting the web inbox link, I get the following error:
Unable to retrieve spec for http://cisco-vm.stjude.org/inbox/gadgets/msg/msg-gadget.xml. HTTP error 500
When I hit the server directly instead of using the VS, it works fine.
I'm trying to use one FQN to get to multiple services, hence the use of my iRule. Config below:
    ltm virtual redirect_cisco-vm.stjude.org_http {
    destination 10.200.44.43:http
    ip-protocol tcp
    mask 255.255.255.255
    profiles {
        http { }
        tcp { }
    rules {
        _sys_https_redirect
    source 0.0.0.0/0
    vs-index 6
ltm virtual vs_cisco-vm.stjude.org_https {
    destination 10.200.44.43:https
    ip-protocol tcp
    persist {
        cookie {
            default yes
    pool cisco-vm.stjude.org_https_pool
    profiles {
        Wildcard_StJude_SSL {
            context clientside
        http { }
        serverssl {
            context serverside
        tcp { }
    rules {
        ciscopca_temp
    source 0.0.0.0/0
    source-address-translation {
        type automap
    vs-index 10
ltm pool cisco-vm.stjude.org_https_pool {
    members {
        dc3051cxn2:https {
            address 10.200.7.28
            session monitor-enabled
            state up
        dc5051cxn1:https {
            address 10.200.7.27
            state up
    monitor https
ltm node dc5051cxn1 {
    address 10.200.7.27
    state up
ltm node dc3051cxn2 {
    address 10.200.7.28
    state up
ltm rule ciscopca_temp {
    if { [string tolower [HTTP::uri]] eq "/"} {
        HTTP::redirect "/ciscopca"
  • We had the same issue. We enabled HTTP VIP to fix the issue.It seems CUC redirects user request to HTTP somewhere/sometimes for CUC inbox services. - Bill.
