Cisco ASR connected directly to two F5 (cluster)
Can we connect cisco ASR router 1000 series directly to two F5-LC in cluster Actif/Passif. (without switch) what configuration do we have to do in ASR ? bridge virtual interface ? I'm not familiar with ASR
Thank you for your help
- jgranieri
From a design perspective if the Primary ASR router reboots/fails then your going to trigger a failover on the primary F5 if directly connected. I am not a big fan of swim lane design since 1 device failover can trigger another when directly connected. I would recommend you add a switch layer between the ASR's and F5's.
You can aggregate/trunk links from the F5 to switch (VLAN) and place the ASR links on that same VLAN as well. There are many different ways to go about this.
Are you planning on using L3 routing on the F5's to ASR's? You can aggregate multiple links to the ASR etc.
- El_Hassan_OUDRH
Thank you for your reply. i will go for your solution.
just to have an idea, the solution to connect directly one ASR to two F5 will work ?
Architecture like that
____ASR1 ___
F5 1 ----- F5 2
Best regards
- jgranieri
You connect a ASR to two F5's. my concern would be single point of failure on that single ASR.
are you using a one-arm design? i prefer to have at least 1 interface on the F5 dedicated for external traffic and one interface for internal. tag all vlans if needed on those two interfaces.
