Cipher suite question
Hi Friends, We are using TMOS 10.2.4 in our LTM box
I saw the following cipher command in my current VIP's SSL profile cipher column. Would like to know what is the meaning of NATIVE command ? Also may i know whether TLSv1 is supported with the following command, my auditor told not to use TLSv1 but use TLSv1.1 or TLSv1.2 but I am not sure whether the following include TLSv1 or not
NATIVE:TLSv1_1:@SPEED:@STRENGTH
Also we plan to use the following new cipher commands, may I know what is mean by !LOW, it mean exclude Cipher strength of 64 bits right ? So is the TLSv1 are those 64bits strength or lower ?
New Cipher
ALL:!ADH:!EXPORT40:!EXP:!SSLV2:!NULL:!LOW:!MD5:TLSv1_1:@SPEED:@STRENGTH
Cipher suite supported in our TMOS 10.2.4
[user1@LTM] ~ tmm --clientciphers 'DEFAULT'
ID SUITE BITS PROT METHOD CIPHER MAC KEYX
0: 5 RC4-SHA 128 SSL3 Native RC4 SHA RSA
1: 5 RC4-SHA 128 TLS1 Native RC4 SHA RSA
2: 5 RC4-SHA 128 TLS1.2 Native RC4 SHA RSA
3: 47 AES128-SHA 128 SSL3 Native AES SHA RSA
4: 47 AES128-SHA 128 TLS1 Native AES SHA RSA
5: 47 AES128-SHA 128 TLS1.2 Native AES SHA RSA
6: 47 AES128-SHA 128 DTLS1 Native AES SHA RSA
7: 53 AES256-SHA 256 SSL3 Native AES SHA RSA
8: 53 AES256-SHA 256 TLS1 Native AES SHA RSA
9: 53 AES256-SHA 256 TLS1.2 Native AES SHA RSA
10: 53 AES256-SHA 256 DTLS1 Native AES SHA RSA
11: 10 DES-CBC3-SHA 192 SSL3 Native DES SHA RSA
12: 10 DES-CBC3-SHA 192 TLS1 Native DES SHA RSA
13: 10 DES-CBC3-SHA 192 TLS1.2 Native DES SHA RSA
14: 10 DES-CBC3-SHA 192 DTLS1 Native DES SHA RSA
15: 60 AES128-SHA256 128 TLS1.2 Native AES SHA256 RSA
16: 61 AES256-SHA256 256 TLS1.2 Native AES SHA256 RSA
- Kevin_Stewart
Employee
Have a look at:
SOL7815: Configuring the cipher strength for SSL profile (9.x - 10.x)
https://support.f5.com/kb/en-us/solutions/public/7000/800/sol7815.html
SOL10262: SSL ciphers used in the default SSL profiles (10.x)
https://support.f5.com/kb/en-us/solutions/public/10000/200/sol10262.html
SOL11444: SSL ciphers supported by BIG-IP SSL profiles (10.x)
https://support.f5.com/kb/en-us/solutions/public/11000/400/sol11444.html
This string essentially says, use the natively supported ciphers for 10.2.4, include TLSv1.1, order by speed, then order by strength. Looking at SOL11444, it appears that TLSv1.1 isn't in the native list, so not sure if it'll work. And I think you're tmm output confirms this.
This means: use all the ciphers in the default SSL stack, but exclude ADH ciphers, EXPORT grade (weak) ciphers, ciphers with 40 or 56 bit export strengths, SSLv2, NULL ciphers, 64 bit ciphers, and MD5. Also include TLSv1.1 (probably not supported) and order by speed and then again by strength.
