SSHSSH_97332
Feb 07, 2013Check Licesne Expiry date from CLI
the below tmsh command gives expiry date at V10 ...... but not at V11 , what is V11 Command ?
tmsh show /sys license
- What_Lies_Bene1
tmsh show sys license works for me on v11.2. What error do you get? - SSHSSH_97332
it works but it deosnot show expiry date ( at V10 it was showing ) ... it Just show start date - What_Lies_Bene1
Mine does on v11.2.1. Then again, I've a time limited license, you probably don't? - SSHSSH_97332
i don' t have time limited license , the idea is i want to know when will my support expire , how to know that ? - What_Lies_Bene1
I'm not sure there is a command for that. Your best bet is to enter the device's serial number here: https://secure.f5.com/validate/validate.jsp - hoolio
I don't believe the support contract info was ever part of the license so it couldn't be returned by tmsh. As Steve said, you can check the support status for one or more serial numbers/reg keys using the https://secure.f5.com/validate/validate.jsp site.
Aaron - SSHSSH_97332
Perfect , This site gives me what i needed ..... Thanks a lot Stteve & hoolio - What_Lies_Bene1
You're welcome.
