Chassis power status
how to get the chassis power status when it does not show from this: )(cfg-sync In Sync)(Active)(/Common)(tmos.sys.hardware) show
Chassis Information Maximum MAC Count 2 Registration Key -
Hardware Version Information Name cpld Type pic Model F5 CPLD Parameters -- -- version 0x8
Name cpus Type base-board Model Intel(R) Xeon(R) CPU @ 2.00GHz Parameters -- -- cache size 8192 KB cores 8 (cores/cpu:4) cpu MHz 2000.000
Name lop Type pic Model F5 Parameters -- -- Boot loader version 1.04 Firmware version 2.18
Name mainboard Type base-board Model F5 Parameters -- -- Assembly serial pca0290z00d9 Board type N/A Level 400 part N/A PCN level PCA-0290-05 REV A Revision N/A
Name qa-crypto2 Type crypto Model Intel Cave Creek Cryptographic Device Parameters -- -- version 1.0.0
Name qa-crypto3 Type crypto Model Intel Cave Creek Cryptographic Device Parameters -- -- version 1.0.0
Name qa-dc0 Type compress Model Intel Cave Creek(2), HW:C1, FW:0.9.0
Platform Name BIG-IP 4000 BIOS Revision OBJ-0433-xx Build: 1.11.132.0 09/17/2012 Base MAC 0:23:e9:51:bc:c0
System Information Type C113 Chassis Serial f5-wgsx-vsll Level 200/400 Part 200-0352-02 REV A Switchboard Serial
Switchboard Part Revision
Host Board Serial pca0290z00d9 Host Board Part Revision
- nitass
Employee
what about system_check -D?
e.g.
[root@VIP4800-R77-S28:/S2-green-P:Active:Standalone] config system_check -D Cpu 1: temperature 26 Cpu 1: fan speed 6617 Cpu 1: temperature 29 Cpu 1: fan speed 6553 Cpu 2: temperature 28 Cpu 2: fan speed 6617 Cpu 2: temperature 28 Cpu 2: fan speed 6428 Chassis fan 1: status 1 - (good) Chassis fan 2: status 1 - (good) Chassis fan 3: status 1 - (good) Chassis fan 4: status 1 - (good) Chassis fan 5: status 1 - (good) Chassis fan 6: status 1 - (good) Chassis fan 7: status 1 - (good) Chassis fan 8: status 1 - (good) Chassis fan 9: status 1 - (good) Chassis fan 10: status 1 - (good) Chassis fan 11: status 1 - (good) Chassis fan 12: status 1 - (good) Chassis fan 13: status 1 - (good) Chassis fan 14: status 1 - (good) Chassis fan 15: status 1 - (good) Chassis fan 16: status 1 - (good) Chassis temperature 1: temperature 19 Chassis temperature 2: temperature 22 Chassis temperature 3: temperature 21 Chassis temperature 4: temperature 26 Chassis temperature 5: temperature 20 Chassis temperature 6: temperature 25 Chassis temperature 7: temperature 20 Chassis temperature 8: temperature 19 Blade (Host temp 1) on slot 2: temperature 40 Blade (Host temp 1) on slot 1: temperature 42 Blade (Host temp 2) on slot 1: temperature 27 Blade (Host temp 2) on slot 2: temperature 25 Blade (Host temp int.) on slot 1: temperature 25 Blade (Host temp int.) on slot 2: temperature 25 Blade (Host Trident) on slot 1: temperature 31 Blade (Host Trident) on slot 2: temperature 27 Blade (Host HSBe 1) on slot 1: temperature 40 Blade (Host HSBe 1) on slot 2: temperature 37 Blade (Host Titan) on slot 1: temperature 30 Blade (Host Titan) on slot 2: temperature 28 Blade (Host HSBe 2) on slot 2: temperature 39 Blade (Host HSBe 2) on slot 1: temperature 41 Blade (Mezz. Nitrox A) on slot 2: temperature 30 Blade (Mezz. Nitrox A) on slot 1: temperature 31 Blade (Mezz. Nitrox B) on slot 2: temperature 26 Blade (Mezz. Nitrox B) on slot 1: temperature 30 Blade (Mezz. ADM1026) on slot 2: temperature 23 Blade (Mezz. ADM1026) on slot 1: temperature 25 Blade (Mezz. Inlet Air) on slot 2: temperature 19 Blade (Mezz. Inlet Air) on slot 1: temperature 20 Blade (Mezz. Octeon) on slot 2: temperature 44 Blade (Mezz. Octeon) on slot 1: temperature 46 Chassis power supply 1: status STATUS=good Chassis power supply 2: status STATUS=good Chassis power supply 3: status STATUS=not present Chassis power supply 4: status STATUS=not present
