Kevan_50436
Apr 21, 2009Changing the body of a response
We have an application that builds and returns pages containing URLs as part of the response body based on how it was called. For example:
Called as: http://a.b.c.d/something/somethingelse
Response includes: http://a.b.c.d/something/changedhere
Called as: https://a.b.c.d/something/somethingelse
Response includes: https://a.b.c.d/something/changedhere
That is fine until SSL is offloaded to the LTM, when this happens:
I have found plenty of articles changing the header, but is it possible to change the body? Or maybe there is an alternate solution that I have missed.
Thanks,
Kevan.
- dennypayne
Employee
Hi Kevan,
You probably just need to enable Rewrite Redirects in the http profile attached to the vip. If you set that to "Matching" or "All" the LTM should capture those references and rewrite them.
Denny - Kevan_50436
Thanks for the idea. It did not fix the problem. - dennypayne
Employee
Sorry...I misread and thought that these references were 301 or 302 responses, but you're saying that the links are embedded in the payload (HTML or whatever). Fixing that is going to be a bit more complicated if the application isn't aware that it's being accessed by SSL on the front end.
I know that some applications (Outlook Web Access for example) will correctly handle this if you pass them a header that basically tells the application when you're offloading SSL (see SOL 6087 Click here ). So that may be one option.
Another option would be to do server-side re-encryption so that the LTM can still do iRules, cookie persist, etc, and the server still gets 443 connections. But this negates the performance gain from offloading SSL on the front end.
You could also enable a stream profile on the https vip that would capture any reference to http://a.b.c.d/something/ and rewrite it as https://a.b.c.d/something/, but that may not be granular enough (it would do that to any reference in the payload, not just the changed ones). I'm struggling to come up with iRule logic to handle that...anyone else have thoughts on that?
Denny - Kevan_50436
That was the pointer I needed, thanks!
The page is simple and requires all references to be changed. It also only occurs on a GET, and the bulk of the traffic comes from POST. So I think this will do the trick:
set ReqMethod [HTTP::method]
when HTTP_RESPONSE {
if { $ReqMethod == "GET" }{
STREAM::disable
STREAM::expression @http://@https://@
STREAM::enable
} - hoolio
Here are a few suggestions:when HTTP_REQUEST { Only rewrite responses if request is a GET if {[HTTP::method] eq "GET"}{ set rewrite_response 1 Prevent server from compressing response content if we're potentially going to rewrite it by removing the compression offerings from the client HTTP::header remove "Accept-Encoding" } else { set rewrite_response 0 } } when HTTP_RESPONSE { Check if the request was a GET and the response is a text content type if {$rewrite_response && [HTTP::header "Content-Type"] starts_with "text/"}{ Configure the find/replace for the stream filter and enable it STREAM::expression @http://@https://@ STREAM::enable } else { Disable the stream filter for this response STREAM::disable } }
This assumes that the server doesn't include http:// references in the redirects. If it does, you could rewrite them following the logic in this post (Click here).
Aaron - Kevan_50436
That is exactly what I needed. Thanks for the assistance!
