Gurus's avatar
Gurus
May 01, 2018
change destination ip of oracle monitor
The following tmsh throws an error.
tmsh modify ltm monitor oracle /Common/$MONname destination $MONnewip
and the error message is:
0107082c:3: Cannot modify the destination address of monitor <$MONname>
  • Where you really able to create a monitor name with $ in front, Or is it you just masking the real value here.
  • Hello,
    this command is use on a script or other code? if that is the case. I suppose you use a variable that is not initialized apparently (value is not set).
    And I confirm you can't create an monitor whit $ in name of monitor.
    SO check your code or script why this variable is not set....
    Regards,
