Anand_4459
Nov 23, 2010Case Sensitive Issue
HelloHTTP Status 404 -
I am very new when it comes to usage of F5 in my DC environment. I have a small problem. Its related to case sensitivities. For example, when I type http://abc.com/xyz it goes to a node and webpage comes up. But when someone types http://abc.com/XYZ i.e, in upper case, we get
error page. Irule that I am using is:-
HTTP::header insert Front-End-Https ON
if {[string tolower [HTTP::uri]] equals
"/abc"} {
node X.X.X.X
Please help.
Andy
- hoolio
Hi Andy,
This might be an issue with multiple HTTP requests on the same TCP connection with some for /abc and others not. If you're using SNAT can you add a default OneConnect profile to the virtual server? If you're not using SNAT, can you create a custom OneConnect profile with a source mask of 255.255.255.255 and add that to the virtual server?
Aaron
