Can some one Help me with initial configuration of LTM
Can some one Help me with initial configuration of LTM.
Here is the requirement:
1.Internal server for Load Balancing the traffic (192.168.10.x:7474,192.168.10.x:7475) 2.VIP Listening on x.x.y.y:443 and it should load balance the above servers. 3.Providing LTM access to internal peoples for changing the configuration.
Regards Visvesh
- R_Eastman_13667Historic F5 Account
- Add the nodes 192.168.10.x:7474,192.168.10.x:7475
- Create a pool with the nodes 192.168.10.x:7474,192.168.10.x:7475.
- Create the VS x.x.y.y:443 and assign the pool to the VS.
Be sure to create an ssl client profile with the ssl certificate and assign it to the VS.
- What_Lies_Bene1
If you're looking for something more in-depth I'd suggest you take a look at this thread, starting around half way down: ">https://devcentral.f5.com/questions/how-to-deploy-f5-big-ip-4200-v-ha-pair-for-web-application" target="_blank">">https://devcentral.f5.com/questions/how-to-deploy-f5-big-ip-4200-v-ha-pair-for-web-application
