sinu_121261
Mar 23, 2014Can reuse fips module after rma.
hello,
One of critical device going for RMA and the device having around 200 ssl keys. is there any way to reuse the fips card/module in the new device?
- Kevin_Stewart
Employee
You cannot remove an internal HSM from the platform to use on another system. Your only real option would be to get the RMA box and the new box to do a FIPS sync across an SSH link. This document will explain that procedure in more details.
- Cory_50405
Noctilucent
Is the device that you are RMA'ing part of a sync group? If so, there are options to sync from the HA peer or a GTM sync group member.
