panas_pianpradi
Jul 24, 2008Can not connect to bigip by using Traffic Distribution Monitor
Dear sir.
I using traffic distribution monitor, downloaded from devcentral, try to connect to the bigip. The result was can not connect. I also attach the capture screen and ssldump. But when i use this application connect to another bigip, i can connect normally.
Please help to investigate this problem.
Thank you.
Panas.
- riya_77581
more detail:
I using traffic distribution monitor(c.net), downloaded from iControl SDK
http://devcentral.f5.com/Default.aspx?tabid=76
connect by
iControl-4.6.3\sdk\support\SOAP\DOTNET\C\gui\DistributionMonitor
error is:
Client found response content type of 'text/html', but expected 'text/xml'.
The request failed with the error message:
Configuration UtilityA problem has occurred in the configuration utility. An attempt to re-load the requested page will be made every 5 seconds while the system automatically recovers from this error. If the configuration utility does not recover from this error within 30 seconds, the error was likely unrecoverable and a customer service representative should be contacted.
Please help
Thank you.
riya - hoolio
Hi Riya,
I'm no iControl expert, but it sounds like the HTTP daemon isn't running correctly. If you access the BIG-IP's web interface through a browser, do you get a password prompt? If so, and you enter the credentials, does the GUI load correctly? You might want to check the httpd logs under /var/log/httpd/ to see if you can get more information on the issue. You can restart the HTTPD daemon without affecting production traffic by running 'bigstart restart httpd'.
Aaron
