Chaithy's avatar
Chaithy
Aug 13, 2017
Can i create a node in common partition and pool ,VS in another partition. Will this work.
I know if Pool is in common and VS in other partition it will work but im not sure of the above
  • Hi,
    You can create objects in common partition and use it in objects in other partitions.
    • Pool in part A can use nodes in common
    • Pool in part A can use monitors in common
    • Virtual servers in part A can use profiles in common
    • Virtual servers in part A can use irules in common
    • Virtual servers in part A can use pool in common
  • Joad's avatar
    Joad
    what is the right partition for vlans and selfIP?
    Can i use common even if vip, nodes and pool are in another partition?
    Thank you
