Can and How F5 APM as SP map SAML multi-valued attribute to network resources like LDAP group resource assign?
We knew that with ldap, we can use the following feature to assign and aggregate different network resources to different LDAP groups. SOL16306: AD and LDAP Group Resource Assign feature https://support.f5.com/kb/en-us/solutions/public/16000/300/sol16306.html
If F5 as SP, got a SAML from an external SAML IdP with the following memberof attribute CN=group1,OU=TestOU,DC=test,DC=test,DC=local CN=group2,OU=TestOU,DC=test,DC=test,DC=local CN=group3,OU=TestOU,DC=test,DC=test,DC=local
Can F5 map each value to APM resources and aggregate these resources for the session?
If yes, how does F5 do it?
- Lucas_Thompson_Historic F5 Account
You can configure the access policy however you like. Any contents of any session variable can result in the assignment of any resource(s) and/or any ACL(s) or execution of any logic you want.
APM as SP will transform a multi-valued attribute contained in a SAML assertion from an IdP to a single session variable with the attribute name, and delimited by a pipe "|" symbol. This multi-valued feature was introduced first in BIG-IP APM v12.0.
To see this, simply configure it and then use the session variable viewer in the GUI or sessiondump command in the CLI.
