kykong_107132
Dec 07, 2007Bypass compression for POST data
Hi All,
I having an issue with compression for POST method JSP file. after compressed, the file size become bigger.
I was thinking to bypass POST method JSP file, but somehow I can't find a way to do that.
the current setting for METHOD is "IS GET OR IS POST", i tried to change the setting but i can't edit this setting.
wondering anyone do compression for POST method JSP file?
Can we change METHOD setting to GET only?
thanks in advance.
regards,
- You can create a copy of the pages node that has a matching criteria of method set to POST. Then turn off compression on the assembly rules.
- kykong_107132
thanks alot.
