Dan_Markhasin_1
Oct 25, 2015Blocking POST with ASM?
I am wondering if there is anyway to disallow the usage of POST using an ASM policy? It seems to be allowed by default with no way to uncheck?
Thanks, Dan
- samstep
Cirrocumulus
If you need to disable POST globally (e.g. you have a virtual server only serving static content) then one way of doing this is via an iRule.
when HTTP_REQUEST { if {[HTTP::method] eq "POST"} { reject } }In ASM policy you can stop POST going through by setting the POST data length to 0 on the File Type and enabling blocking on "Illegal POST data length" violation.
Hope this helps,
Sam
- Dan_Markhasin_1
Thanks Sam, it does help! :)
