Ray_74718
Jun 01, 2016block ip options header
Hi all,
can BIGIP block or filter packets with IP options header ? e.g. packets with incorrectly formatted options.
Thanks!
- Vijay_E
Cirrus
I think you would have to use ASM module. You may be able to achieve some functionality using iRule in LTM, depending on your requirements.
- JG
Cumulonimbus
You can write an irule to do this. See: https://devcentral.f5.com/wiki/iRules.DATAGRAM__ip.ashx .
- JG
Cumulonimbus
And also see this one : https://devcentral.f5.com/wiki/iRules.FLOW_INIT.ashx .
