Bigsuds output on Graphical Interface
Hi all,
Let me explain my challenge.The company that I work for has an application team that can't have direct access to BigIP devices, but they need to check about the object status, availability of pool members, VS etc.The bigsuds is a perfect solution, I can write a script and get all information about the objects.
I need to get this output from the script and put on a friendlier graphical interface that looks like network map, maybe a html page or csv.Do you guys have any tip on How to accomplish this task?What do I need to learn or research for make it.
Thanks in advance and sory about my english ;)
Guilherme_1990, there are a lot of open source graphics packages out there. The tool you use really depends on how you want the information exposed to your end users. If you are building a web app, Google Charts are a great option to build a dashboard with graphs, status indicators, and data tables. I'm sure there are many others out there you can experiment with.
-Joe
