Bret_McGinnis_1's avatar
Bret_McGinnis_1
Feb 23, 2006
BigIP Reboots while running an iRule
I have two iRules that that work together applied to a VIP. The first iRule,which can run stand-alone, works fine standalone. The second irule, which cannot run stand-alone, also works fine.
The problem occurs only after a pool fails and then becomes available again. On the first request after the pool becomes available the BigIP reboots. This happens consistenly.
I have run many tests and it seems that after a specific point in the execution of the second iRule, any request to the pool once it becomes available causes the BigIP to reboot. It does not reboot while the second iRule is running. Only on the next request to the pool after it is available.
Any suggestions?
Regards,
  • bl0ndie_127134's avatar
    bl0ndie_127134
    Historic F5 Account
    Can you please report the problem with support so that they can assist you in harvesting the necessary information to determine what's going on? Thanks!
  • Hi,
    Already done. I sent it to them first. They asked me to post here as well.
    Regards,
