Vishnu_G_325405's avatar
Vishnu_G_325405
Feb 27, 2018
bigip monitor is not visible in the pool monitor list.
The bigip monitor is not visible under the pool members, but I can see them in Servers. How can I make it available for the pool/pool members as well.
  • nathe's avatar
    nathe
    Vishnu,
    I suspect you created the monitor in the "local Traffic" section of the GUI. If so, then you would need to create the monitor under DNS - GSLB - Monitors.
    Have a check.
    N
