Manuel_Rodrigu2
Sep 17, 2008bigip_link monitor failing through Prolexic
I have a LC with three different links, one of them through Prolexic. I'm trying to add it to my GTM. Boths port 22 and 4353 are opened between devices. MTU size has been reduced to 1476 which is the maximum allowed through Prolexic GRE tunnels.
Then I add the LC pair to the GTM using bigip_link monitor and everything goes ok and it discovers all the virtual servers in the LC.
The problem is that all the resources (virtual servers) through Prolexic link go red.
Any ideas? Is bigip_link using any special port appart from 22 and 4353 that might be blocked?
Thanks for your help.
Manuel
- y_29571
Hi Manuel,
1) Please check TCP 22,TCP 443, TCP/UDP 3453 betwwen GTM and LC
2) check the validation of SSL certificate of LC
