Maneesh_72711's avatar
Maneesh_72711
Mar 07, 2018
BigIP DNS and LTM vCMP Guests on same i10800
Are there any concerns when spinning BigIP-DNS and LTM on the same I Series box (i10800). Someone mentioned it is better to keep them on separate hardware. I got Big-IP DNS which will be resolving to Internet DNS queries and a LTM which would be hosting the Public Sites. Do you guys foresee any concerns with hosting both the BigIP DNS and LTM on the same Box under different vCMP Guest instances.
  • Nothing. You can configure it even in the same vcmp guest and it will work like a champ as long as you have right resouces (CPU/memory/disk space) allocated.
    -Jinshu
