Javier_Somoza's avatar
Javier_Somoza
Nov 14, 2017
BIGIP cluster SSL problem
Hi all
BIGIPv13 2 node cluster environment.
A virtual server acting as reverse proxy working correctly in node 1. If I set the second node as active, cannot connect to the ssl sites this virtual server is publishing. It seems any SSL/certificate related problem (as seen in the browser).
But the configurations are "in sync" so how can the second node act different compared to the first one? How could I troubleshoot this?
Thanks all!
