BIG IP Monitoring is not working
BIG IP Monitoring for configured nodes was not working in the primary device. But the nodes are up and running fine. Please help me to resolve this issue.I had checked the tmm error message its stating me like this. notice session_process_pending_event_callback ERROR
- Manik_282561
Got the below error in LTM logs:
Bigd PID 7147, instance 0, throttling monitor instance probe because file descriptor limit 65436 reached.
- nathe
Cirrocumulus
See the following solution The bigd process may stop working when the file descriptor reaches its limit
Are you using 11.6.x or v12.x? If you're running 11.6.x you may need a hotfix to resolve. I would raise a case with f5 support.
N
