BIG Ip hot fix error
I am trying to do a hotfix update on 10.2.4 from HF7 to HF9 . I am running base image BIGIP-10.2.4.577.0.iso trying to instal hotfix on HD1.1 from HD1.2 .
HD 1.2 is current active partition so am installin in on HD1.1 when i run the install it gives error cant find requested disk HD1.
Please help
- nitass
Employee
can you paste the screenshot?
- Abi80_167352
Image uploaded
- nitass
Employee
may i have the command you used (to install)?
- Abi80_167352
tried installing it fro GUI
- Abi80_167352
Hi Nitass we also tried from CLI
- nitass
Employee
i suspect you are hitting this bug. can you open a support case to verify?
Bug 485936 10.2.4 HF9 rollup breaks support for partitioned disk format
- Abi80_167352
can provide the link
- nitass
Employee
it is not available. to verify and get it fixed, you have to go through standard support process (i.e. opening support case).
- Abi80_167352
Aslo i have created the nee volume but some error in that too
- nitass
Employee
i thought you are using partition disk formatting scheme.
if yes, to use volume disk formatting scheme, you have to format (whole) disk before.
sol10817: Determining the disk-formatting scheme used by a BIG-IP version 10.x system
https://support.f5.com/kb/en-us/solutions/public/10000/800/sol10817.html - Abi80_167352
Hi Nitass
ran lvsan on the shell could not find any output which concludes we are using partition disk formatting scheme
can you suggest us anything which would help us
- nitass
Employee
i would open a support case to verify and see if support can provide engineering hotfix.
