jkreyes_313300's avatar
jkreyes_313300
Jun 25, 2018
BIG IP Edge Client prompts for configuration inspection, and the site is not in the trusted site list
Whenever i connect to our corporate site using BIG IP Remote Edge Client, there's always a prompt saying " The site 'company A' is attempting to inspect your system configuration. This site is not on your Trusted Sites list.
Then there's the option to add this site to the Trusted Sites list.
The problem is that it keeps on appearing everytime the user connects. Is there a way to add this to the trusted site list permanently or is there a way to suppress this prompt?
  • Hi jykreyes, did you happen to get a resolution to this issue?
