BIG-IP Auto backup configure and send SCP/SFTP using crontab
Prerequisite:
- Secure Copy Protocol server (SCP) server.
- BIG-IP CLI Access- recommened root user.
Configuration Steps:
Step#1: Login BIG-IP cli and generate ssh key pair.
Nothing to do.. Press Enter again and again.#ssh-keygen
Step#2: Push the id_rsa.pub key to remote scp server. So that without password we can login. ssh-copy-id scp_user@<remote-scp-ip>
#ssh-copy-id -i /root/.ssh/id_rsa.pub [email protected]
Now you can check ssh public key authentication working by tring ssh login. ssh [email protected]
Now test that public key authentication working. Simply do ssh on scp server: ssh scp_user@scp_ip
If it's login remote scp server without password now good to go next step.
Step#3: Make directory where the backup will stored.
mkdir /var/ucs
Step#4: Set schedule through crontab.
crontab -e
Step#5: After open cron file click i for insert and paste backup taking command.
0 1 * * * tmsh save /sys ucs /var/ucs/$(/bin/hostname).ucs && scp /var/ucs/$(/bin/hostname).ucs scp_user@<scp_server_ip>:/home/scpnet/F5/DC_F5_Node_02/$(/bin/hostname)-$(date +\%Y-\%m-\%d).ucs
- For save click ESC
- :wq
Step#6: Now verfiy the crontab by
crontab -l
Note: This is the simplified 😊 version of below two article. I am tried to simplify and straightforward guide.
