Basic question on F5 Load Balancer settings
Hello
I am running an application that connects to Microsoft Exchange 2010 via an F5 Load Balancer. Our application is MAPI based and basically functions as a MAPI client that needs to connect to Exchange, the same as Outlook, except there are hundreds of MAPI connections to Exchange per our application server.
Exchange has a CAS array (cas-ny.domain.com) behind which sit several Exchange CAS servers.
cas-ny.domain.com is a virtual hostname/IP that is fronted by the F5.
I understand there are several settings on the F5 that are relevant to my application:
Session Timeout Keep Alive Polling Interval Session Persistence
Could someone explain how they relate to my application?
- nathe
Cirrocumulus
If you've got tmos v11 then you could download the latest exchange iApp and configure a mapi VS using the iApp template. At least this will show u the recommended f5 setup for Exchange, persistence etc...
- Newbie2012_1655
Hello Nathan
Thanks for answering. I'm not actually from the team that manages the F5, I'm from the application side, just wanted to understand a bit more about the the F5 side :)
