Richard_Kim_270
Aug 15, 2008Basic iRule redirect help
Hello people. I would like to add a line that will detect a url/file for "login.aspx" and redirect it to "default.aspx*". here is my current iRule:
when CLIENT_ACCEPTED {
set vmapppool06 [LB::server pool]
switch -glob [string tolower [HTTP::uri]] {
"*/report/*" -
"*/reports/*" -
"*/admin/*" {
pool vmqaapppool06_reports
"*/imaging*" -
"*/billing*" {
pool vmqaapppool06_image
default {
pool $vmapppool06
- The_Bhattman
You could use the following. . . if { [HTTP::uri] ends_with "login.aspx" } {HTTP::redirect "http://something.anything.com/default.aspx" }
or. . . if { [HTTP::uri] ends_with "login.aspx" } {HTTP::uri /default.aspx }
Hope this helps.
CB
