Mike_McCardle_1's avatar
Mike_McCardle_1
Dec 19, 2006
Basic iRule not working after upgrade
Hello All,
After an upgrade from 4.5.10 to 9.1.1, I cannot for the life of me get this iRule to work. it's pretty basic but for whatever reason, it doesn't want to work. I have a VS listening on port 80 for web traffic coming in. based on the URI it will be directed to 1 of 3 pools I have setup. The HTTP requests will all come into http://webhost.domain.com/____ . At the end of the request (URI) will either be /Jive, /WebNow, or a couple other strings. I need to direct requests containing "jive" to the Jive-Web pool, requests that contain "webnow" to the WebNow pool, and all others to the Weblogic pool. Any help is appreciated. Thank you.
if { [HTTP::uri] matches "/jive" } {
use pool Jive_Web
elseif { [HTTP::uri] matches"/webnow" }{
use pool WebNow
else {
persist cookie insert wldevpool
use pool Weblogic
  • wrong script in there, I was trying to play with different commands to get it to work. this is the one that was upgraded and I am trying to use:
    if { [HTTP::uri] =="/jive" } {
    use pool Jive_Web
    elseif { [HTTP::uri] =="/webnow" }{
    use pool WebNow
    else {
    use pool Weblogic
    thanks.
  • Deb_Allen_18's avatar
    Deb_Allen_18
    Historic F5 Account
    You mentioned that you want to direct traffic if the URI "contains" that string, which may be the problem. Try using the "contains" or "starts_with" operator instead. You might also want to make the comparison case-insensitive, and a switch statement might be in order as well -- try one of these:
      if { [string tolower [HTTP::uri]] contains "/jive" }{
        pool Jive_Web
      } elseif { [string tolower[HTTP::uri]] contains "/webnow" }{
        pool WebNow
        pool Weblogic
    or:
      switch -glob [string tolower [HTTP::uri]] {
         Adjust wildcards as necessary.
         "/jive* is equivalent to "starts_with /jive"
         "*jive* is equivalent to "contains jive"
        "/jive*"    {
          pool Jive_Web
        "/webnow*"  {
          pool WebNow
        default     {
          use pool Weblogic
    HTH
    /deb
  • Thank you much! I switched it to use the contains and the tolower command and all is well. Thanks for the input!
