Bandwidth Control Management @ 11.3
http://support.f5.com/kb/en-us/products/big-ip_ltm/manuals/product/tmos-implementations-11-3-0/8.html
at the end of the page it is mentioned :
In the example, the ISP sets the maximum bandwidth at 200 Mbps. Of that bandwidth, a maximum of 20 Mbps is allocated to each user. Of that allocation, application traffic is apportioned, as follows.
- 50% applies to browser traffic (HTTP)
- 20% applies to P2P
- 4 Mbps applies to video
- 1 Mpbs applies to Voice over IP (VoIP)
How will BIGIP identify browing , from P2p From Video ?
- What_Lies_Bene1
Good question. Anyone? exactly the same question i have (11.4 documentation is the same), a bit of a shame F5 introduces new things but doesnt explain it clearly / correctly.
next to the issue above there is an error in the document, first it is mentioned:
but in the end when they are talking about dynamic polices (in which they confuse matters by using two names: dynamic_bwc_policy / bwc_dynamic_policy200) it is mentioned:When you apply a bandwidth control policy to a virtual server, packet filter, or route domain, you can apply only one policy at a time, and that is a static policy.
so i need to apply a dynamic policy to a virtual server, which isn't possibleTo activate this policy, the ISP needs to create an iRule to attach the policy to a user session, and then apply the policy to a virtual server.- Susan_Allen_872Historic F5 AccountThe bandwidth controller is only an enforcer. To identify a flow and map it to a category, you'll need to use iRules, Policy Enforcement Manager, or Access Policy Manager.
- Mate_132781
