Hannes_Rapp's avatar
Hannes_Rapp
Apr 27, 2015
ASM System Error
(Solved with a workaround)
F5 v11.5.1 HF8
Have tried to deprovision/reprovision ASM - no help;
Furthermore, "tmsh save sys conf" works without any problems. The ASM module itself is working.
Error received after issuing the command: "tmsh load sys conf":
 Loading configuration...
  /config/bigip_base.conf
  /config/bigip_user.conf
  /config/bigip.conf
01070710:3: Can't save/checkpoint DB object, class:asm_http_method status:13 - EdbCfgObj.cpp, line 127
Unexpected Error: Loading configuration process failed.
