Asif_Pasha_3042's avatar
Asif_Pasha_3042
Oct 02, 2017
ASM Policy: URI Entry point
Dear Experts,
Please share more light on URL entry point. In my ASM policy https://happy.com/ is the common url & we have many URIs under it example: https://happy.com/abc/(with login page). May be around 10 applications similar to this. And like https://happy.com/xyz(without login page) two to three applications.
Please advise what should be configured under parameter for entry & exit points.
Thanks. Asif
  • You are asking a fairly specific question with fairly general information. You probably would want to create separate login pages for each web application. Depending on how different they are you may actually want to have different ASM policies for each web application.
