ASM policy in transparent mode causes corrupt web page
I have a ASM policy configured in Transparent mode. When it is turned on, the web page does not behave correctly, and using a HTML capture, the HTML is longer (or actually has more calls to the webserver). Turning the policy off of the Virtual Machine, the web page behaves as expected. Creating a new policy for the VM and the web page behaves as expected. Could the original policy be corrupt? It worked for a year until a recent code deploy. Creating a templet from the original policy and then a policy off of that, the behavor is the same as the original policy.
- nathe
Cirrocumulus
I just wonder if the application language is different? Just a thought really.
- nitass
Employee
are you using any asm feature which injects script to client?
if yes, can you try to turn it off?
- D_Tucker_134543
Nope. It was a generic policy. No irules or injects. - nitass
Employee
you are not using feature such as web scraping, csrf, etc, are you? - D_Tucker_134543
No. The code is all coming from Websphere. HTML and Java script.
- nitass_89166
Noctilucent
- D_Tucker_134543
Nope. It was a generic policy. No irules or injects. - nitass_89166
Noctilucent
- D_Tucker_134543
F5 support found the problem. Chunking with ASM. And Data Guard was masking fileds it thought were credit cards... Thanks Support!
