ASM Policy Assigned System Names
I've attempted to pull the assigned system names with the iControl Rest API as well as the F5 Python SDK (I thought it might be easier to interact with the rest API using the SDK) but I'm running out of ideas on how to do this.
Has anyone ever tried to do this programmatically? If so, I'll take any suggestions using any method, system, or API. I've been at this off and on for the past few days with no success whatsoever.
Thanks to anyone who can help :)
- gsharri
Altostratus
Sorry, I don't have a solution to your issue but it did make me want to say "Crooooooooooow!"
- samstep
Cirrocumulus
I can't quite get what "System Names" are you after in ASM? Is it the list of Virtual Servers which have the ASM Policy X assigned, or is it the list of ASM Signatures for systems such as UNIX, MySQL, PHP, Windows, Apache etc assigned to an ASM Policy? Can you clarify? I am confused as Systems (e.g. Unix) don't get Assigned to policies, signatures do. The Systems are only used as a filter on a list of available signatures....
