TonyB_01_132381's avatar
TonyB_01_132381
Dec 12, 2013
ASM module licensed but not enabled
Hi, I have an LTM1600 running 10.2.4.577.0. I have added a license for the ASM module & now in the licensing info the ASM module is listed in the active modules section with an unlimited (perpetual) license. However, the ASM option does not appear in the lefthand pane of the GUI screen. Is there something I need to do to enable the module?
  • nathe's avatar
    nathe
    TonyB
    See the product matrix sol10288
    This seems to suggest you need v11.0 for LTM and ASM on 1600. May be reading it wrong but check it out.
    Rgds N
  • Nathan,
    Thanks for your response. I have upgraded to 11.2.1 & the ASM is now enabled.
    Thanks again.
