Dave_P_130251's avatar
Dave_P_130251
Dec 13, 2013
ASM maximum number of entries in manual learning?
I noticed on my ASMs that occasionally the entries for say an attack signature show 0 Recent Incidents or if you go into a HTTP protocol compliance entry it says 1 but when you click on it there is no request data. Has anyone else seen this? Is there a retention period for learned entries or a max number that can be stored on a specific ASM? I have 10 or so policies running in learning on this ASM.
Any help would be appreciated.
  • this is a normal behavior, if you have to much records over all policies. I don't know the possible number of records and a way to increase the number of records, but older one are lost, if the limit is reached. After that you will only find a learning suggestion without detailed informations.
